1 - 3 of 3 Posts
while at a part throttle situation,my v92 cuts out like its out of fuel.it seems to do it worse as my tank is half full or less.bike has very low miles on it.any help will be appreciated.
It Sounds As Though You Have A Fuel Pump Problem (low Pressure)firstly Prime The Pump By Having Ignition On Toggle The Kill Engine Switch 3 Times At 5 Sec Intervals.this Should Prime The System Make Sure That You Hear The Pump Activating.(if It Does Not Prime Check Wiring At Switch On. Voltage Should Be Present For 2 Secs)
If No Improvement Check To See If You Have Fuel Pressure, If No Pressure Replace The Pump
Good Luck
You might want to clean the throttle body. you would be amazed at the problems it causes with performance of a Vic.
1 - 3 of 3 Posts
