1 - 3 of 3 Posts
About to pull the tank to remove the fuel pump. I don't have an assortment of metric bolts, or even a hardware store close by, can anyone tell me the bolt and thread type to pull the fuel door? Thanks,
Ok, I guess nobody knows, how about this, is it Metric or American threads?
Discussion Starter #2
Ok guys, can't believe that no one knows the bolt size but, has anyone used compressed air to remove the fuel door. I don't know if that's the correct name for it but maybe someone can enlighten me on that. But anyway, it seems that if you wrapped a rag around a blow gun and stuck it tightly into the filler hole it should pop the fuel door right out. Comments???
Sent from my SM-N900T using Tapatalk
1 - 3 of 3 Posts
