1 - 4 of 4 Posts
Kingpin and Vegas frames are the exact same. Only difference in the 2 models is the front forks and front wheel setup; the front and rear fenders. The rear fender will bolt straight up to the Vegas and vica versa on the Kingpin. I have a kingpin rear fender on my Vegas.
So with that stated the bags should fit without an issue.
cool that's is what I thought I was just curious about the whole year model difference between 2004 and the 2008 if it was that big of a change if anything at all.
an issue
Though if you keep the Vegas rear fender you may run into interference with the turn signals, depending on the bags.
1 - 4 of 4 Posts
