First off the map is a "Hard" memory item, and it will never be lost unless it is removed for another map
Next up. If the pipes did not come with a map card, The current slip on map will work with a little tweak of the TPS adjustment. Maybe not 100%, but pretty close to 95%. If it came with a map card then use it.
If you have no other mods the Vic mapping is all you need. No reason to add the complications of a controller
