1 - 4 of 4 Posts
2005 Victory Touring Cruiser
Hello all! I recently purchased a 2005 Victory Touring Cruiser but for some reason the rear lights aren’t turning on when it’s running. When I apply the brakes I get lights and the indicators work but they won’t turn on otherwise. I went through and checked all the connections to make sure they are secure and replaced all the fuses. Not sure if anyone else has seen this before or has a fix.
Did you check the bulbs. I had to change the bulbs in mine often. Clean the contacts, do you have the correct light bulb in it.
Reactions: rainman123
Discussion Starter · #3 ·
The bulbs are working fine, I checked to make sure they are seated with good contact. Again they light up when the brake is engaged and the turn signals are activated they just don’t stay on when the bike is running which is a huge safety concern especially at night
1 - 4 of 4 Posts
