1 - 2 of 2 Posts
I have what I thought was going to be a simple problem. The brake light stays on. My problem started when the switched brake light wire and ground shorted out blowing the fuse. I found this, repaired it and replaced the fuse. Everything functions correctly except the brake light wire has continuous voltage on it without the brakes applied causing a continuous brake light. I read somewhere it could have damaged my ECU. It seems it said the brake switch wires connect to the ECU and then it provides power to the light. HELP!!!
Have you obtained the service manual and traced the brake light circuitry to determine if they do pass through the ECU as you suggest?
1 - 2 of 2 Posts
