1 - 5 of 5 Posts
my bike was running great then i tried to start it it seems not to be getting gas i turn the key i can hear the fuel pump kicks on but it just turns over not sure if this could be a sensor or what any ideas?? also s 80e from what i have found thats a voltage error im assuming since battery is dieing from trying to start it thats why this has started coming up
and if sensor how many are there on bike and where might i find them i know i sound like a dummy ..well i am lol
any help would be great
thanks
I'm only agreeing with what you said. Your description sounds as if you have low voltage, and I'm only trying to help:D
Are you seeing the RPM needle jumping as you crank the engine?? If not go to the crank shaft position sensor and check the connection. Located in the front area of your engine block. My is on the left front of my 03 cruiser.
1 - 5 of 5 Posts
