1 - 4 of 4 Posts
Hello folks, just picked up my first Victory on Wed. On my way home from work last night I noticed my turn signals stopped working, brake and head lights working as normal. Any tips on where to start?
Have you done any thing to the bike?
Start checking fuses and relays. Check bulbs too.
If there good pull the seat look for pinched wires make sure your battery cables are tight.
Being a 07 your battery might be going bad. Put a full charge in it and have a battery shop check its strength.
Pull head light and check wires inside there
Only thing I did was remove the windshield. Worked on the way to work, did not on the way back. All other lights work normally, will check the fuse in the morning. Battery is 6 months old and has a full charge.
Checked all the fuses, found some mil corrosion on em, changed em all out, found the turn signal relay was not seated all the way. Popped it back in and looks like we are good to go. thumb up
1 - 4 of 4 Posts
