1 - 3 of 3 Posts
good day gents,
like the title says when im cruising she vibes a lot, tingles in the hands and feet. Now this only happened this year.
Only thing extra I did this year was pop off my throttle cables for lube. I put them back where they were but maybe not exactly/ Would this cause imbalance??
I called a dealer pretty far from me and he said throotle may need sync
any advice is good advice
I think the throttle body sink is BS
Sit on bike and see if you can move the bars. Maybe the rubber bushings are shot.
Check your tires see if they are worn out if the wheel weights are still on. Run your hand over tire feel for cupping or not smooth.
Check bolts for being tight
Lubing cables would not cause a vibration if thats all you did.
I checked the bars seem good. Front tire has a few weight pieces on it but the back tire has nil none. Should it?? Maybe that's the vib?
1 - 3 of 3 Posts
