1 - 6 of 6 Posts
I have a line on two used but seemingly really nice 2009 Visions.
anything I need to know about that particular year? other buying advice? coming to Victory from a Honda ST1300..
thanks - KS.
check tires if the rear is cupping it will coast you $250 to replace
check break pads fronts will coast $84 bucks for the pair
Ask what down loads he has done
Ask what exhaust he has what does he have for air filters. There might be 2
Ask if there is Ipod cable 30 pin is the best
See if both heated grips work and the windshield goes up and down smoothly. If you can take it for ride see if cruse control works.
Do you have photos or link to bike
buying help
yes I've seen pix. in fact I'm driving to MN tomorrow and will look at one of them at "Fury" on Tues...(in or near Minneapolis)
as far as you know nothing "year specific" about the 2009's?
KS.
say there 6 bolts that hold the front fender in place
make sure there tight. 2 on the out side and two on the inside.
The in side was might be loose and cracks by the holes
1 - 6 of 6 Posts
