1 - 6 of 6 Posts
Good evening all,
The turn signals on my 2010 Jackpot do not turn on when I flip the switch. Also, when I flip the emergency switch the signals do not flash. However, if i leave the bike turned off for an extended period of time and I turn on the emergency lights all four will light up and stay on. No flash. If I flip the switch off and then on again they will not light back up. I've had the same thing happen very sporadically with the turn signal. Power off for a long time, key on, flip turn signal switch and the corresponding side's signals with stay on. No flash. Push the button in to turn off they wont come back on. I've literally tried everything to figure this out. However, could this be something with the ACM on the motorcycle? What else could it be?
Sounds like a burnt ACM. I could be wrong tho.
I think you're probably right. It's not the switches and it's not the wiring. It has to be the ACM. Where is the thing on the 2010's?
Would this be something covered under warranty?
Kevin,
I've looked at all of the 15 midget fuses for the lights and swapped the relays out just to be sure. Nothing.
1 - 6 of 6 Posts
