1 - 13 of 13 Posts
I was looking in the manual yesterday and it tells me that the 8 Ball comes with the 100 engine, but the cheese wedge on the side says 106?????? WTH???? I bought it used with 1700 miles last October. Is the manual incorrect-- is it the 100 or 106 and did somebody change the cheese wedge or does it come wrong from the factory?:confused:
Anybody else have one?
I believe it was 2011 when Vic went to the 106 in all bikes. Vic was probably using up old literature hoping no one would notice.
Manufacturer Victory
Model Year 2011
Model Kingpin®
Price *$12,499.00
Color Two-tone Pearl White / Sandstone Metallic
DIMENSIONS
Length 99.9 in. (2,537 mm)
Weight Dry: 666 lbs. (303 kg)
GVWR: 1,234 lbs. (560 kg)
Ground Clearance 5.8 in. (148 mm)
Wheelbase 65.6 in. (1,666 mm)
Seat Height 26.5 in. (673 mm)
ENGINE
Engine 4-stroke, 50° V-twin, single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Displacement 106 ci
Bore x Stroke 101 x 108 mm
Torque 113 ft. lbs.
Compression Ratio 9.4:1
Fuel System Electronic Fuel Injection with dual 45 mm throttle body
Fuel Tank Capacity 4.5 gal. (17 l)
Clutch Wet, multi-plate
Cooling Air / oil
Exhaust Staggered slash-cut dual exhaust with crossover
Oil Capacity 5 qt. (4.75 l)
DRIVETRAIN
Transmission 6-speed overdrive constant mesh
Primary Drive Gear drive with torque compensator
Final Drive Carbon fiber reinforced belt
BRAKES/WHEELS/TIRES
Brakes System Type: Conventional
Front: 300 mm floating rotor with 4-piston calipers
Rear: 300 mm floating rotor with 2-piston calipers
Wheels Front: 18 x 3.5 in.
Rear: 18 x 5.5 in.
Tires Front: 130/70 B18 Dunlop® 491 Elite II
Rear: 180 55-B18 Dunlop® D417
ELECTRICAL
Battery 12V (18A)
OPERATIONAL
Suspension Front: Inverted cartridge telescopic fork, 43 mm diameter; 5.1 in. (130 mm) travel
Rear: Single, mono-tube gas shock absorber; cast aluminum swingarm with rising-rate linkage, preload adjustable spring; 3.9 in. (100 mm) travel
Rake 32.8°
Trail 5.4 in. (138 mm)
In the manual the Kingpin and Kingpin Ness shows the 106. It is only the 8 Ball model showing the 100.
2011 Kingpin 8-Ball had the 106/6-speed.
The 100" 8-ball models had a 5-speed transmission. If you have six gears, it's a 106".
What HC said thumb up......2010 was the last year for the 100
Since I made this thread, somebody snunk in my house while I was gone and switched manuals with one that has the correct numbers. When I looked today it shows the 106 CID engine. At 58 years of age this is starting to scare the crap out of me! How could they switch my manual???????:crzy:
Gettin old sucks. :(
That sounds spooky to me.
Well I looked again and discovered I am NOT going crazy!!!! Is the book wrong?
Ok let me clear this up a bit. The manual says the displacement for the 8 Ball is 106, but the engine is listed as the Freedom 100/6, while the Ness and Kingpin is the Freedom 106/6. What am I missing? This just an oversight in the Manual???
Discussion Starter #13
you can lead a horse to water..........
I am not thirsty--just asking what appears to be a stupid question to some.
The VIN indicates my bike has the "lower performance" engine. (doesn't ride like lower performance....) So I am GUESSING that is why it is referred to in the manual as the Freedom 100 even though it is 106 CID.
1 - 13 of 13 Posts
