1 - 4 of 4 Posts
Can somebody please take a picture of the drain plug? I have a manual, but the picture shows a small allen set screw just behind the kickstand. I bought a Witchdoctors magnetic plug and it does not look like it will fit in the same place. I just want to make sure before I start changing the oil.
I believe its a 6mm "bolt" on bottom back left hand corner right by the oil filter. Should be straight in from the oil sending unit.
Look on youtube there might be a video there showing you how to
oil.jpg you can see in the diagram 8 and 9 the two most important parts on the bottom of the case.. Be careful with the crush washer when reinstalling or it will leak. http://parts.polarisind.com/Assemblies.asp
1 - 4 of 4 Posts
