1 - 4 of 4 Posts
Hi Guy's,
I was wanting to ask if any one out there knows if a 2011 trans ( Nuetral Finder ) in a Vegas would go in a earleir model ( 2009 ) ?
It would be nice to stop looking for Nuetral all the time and by what i've read i can increase my service period.
I just thought it would best to ask b 4 i did anything rash.
Cheers
AL
2009 part numbers
1 5135879 Fork, Shift, Mainshaft 2 Usage
2 5134294 Rail, Shift Fork 2 Usage
3 1332686 Asm., Shift Drum, 5 Speed [Incl. 5,6] 1 Usage
3 1332685 Asm., Shift Drum, 6 Speed [Incl. 5,6] 1 Usage
3 7661023 Pin, Solid 2 Usage
4 5135880 Fork, Shift, Countershaft 1 Usage
5 5334457 Pin, Indicator, Shift Drum 1 Usage
6 7042307 Spring, Pinshift Indicator 1 Usage
7 5132139 Adaptor, Shift Shaft 1 Usage
8 7041583 Spring 1 Usage
9 1341416 Asm., Shifter Ratchet [Incl. 10] 1 Usage
10 7710534 Ring, Retaining 1 Usage
11 7042087 Spring, Torsion 1 Usage
12 1341402 Asm., Roller Follower 1 Usage
13 7518937 Screw 1 Usage
14 5136727 Star, Shifter 1 Usage
15 7517384 Screw 1
2011 part numbers
1 5137137 Fork, Shift, Mainshaft, 6th 1 Usage
2 5136947 Rail, Shift Fork 2 Usage
3 5136881 Fork, Shift, Mainshaft, 4th 1 Usage
4 5136754 Fork, Shift, Countershaft 1 Usage
5 7661023 Pin, Solid 2 Usage
5 1332792 Asm., Shift Drum, 6 Speed [Incl. 6,7] 1 Usage
6 5334457 Pin, Indicator, Shift Drum 1 Usage
7 7042307 Spring, Pinshift Indicator 1 Usage
8 5132139 Adaptor, Shift Shaft 1 Usage
9 7041583 Spring, Shifter 1 Usage
10 1341416 Asm., Shifter Ratchet [Incl. 11] 1 Usage
11 7710534 Ring, Retaining 1 Usage
12 7042087 Spring, Torsion 1 Usage
13 1341402 Asm., Roller Follower 1 Usage
14 7518937 Screw 1 Usage
15 5137600 Star, Shifter 1 Usage
16 7517384 Screw
as you can see they are different
1 - 4 of 4 Posts
