1 - 6 of 6 Posts
My Hammer is very inconsistent at starting. It sounds like the battery charge is low. Sometimes it starts right up and the next second the engine barely turns over. The battery checks out fine. If you’re try it more than 2 or three times then it looses all power but I can wait a few minutes and some times it starts right up ( without any charging of the battery. If I push start or jump start it, it’s starts right up every time. This happens hot or cold starts. HELP
Do this once a year
Are you sure you've had the battery load tested? That sure sounds like a bad battery to me.
I would think battery or battery connections. Have the battery load tested, a lot of battery dealers, parts stores will do it for free.
Reactions: otab
Sorry didn't see the year of your bike. Forget my post
1 - 6 of 6 Posts
