IF I HAVE TO REMOVE EXHAUST IN ORDER TO PULL AXLE SHAFT OUT RIGHT SIDE OF BIKE CAN I DURING RE INSTALL ROTATE SHAFT SO THAT ON NEXT TIRE/WHEEL REMOVAL THE NUT OF SHAFT WILL BE ON RIGHT SIDE AND THE SPLIT WASHER WILL BE ON LEFT SIDE ? WHAT I DID THIS TIME WAS D I SLID OUT AXLE TO THE RIGHT JUST ENOUGH TO REMOVE SPLIT WASHER THEN I REMOVED AXLE SHAFT WITH NUT STILL ATTACHED OUT TO LEFT SIDE .
