1 - 10 of 10 Posts
I have a very nice 2016 gunner with ABS on it, my issue is that as the front and rear wheels are now not stock, it has highball hubs laced to custom rims, 23" front
now the bike throws up an ABS light after a few miles
anyone know a link to a wiring diagram so I can just try cut power to the ABS lamp, that red thing is so damn bright at night LOL
There are aftermarket ABS rings to restore functionality.
Check the PDF manuals Bbob has in signature.
From what I've seen they usually don't include the wiring though. :(
Discussion Starter · #3 ·
thanks, I had no idea there was aftermarket ABS rings, very interesting,
I expect it be expensive to get them here inthe UK but if its gets rid of that damn bright red light.. well worth it
cant turn ABS off with digital wrench, and the light is canbus controlled so cant even just cut a wire LOL
Reactions: IndyVictory
Little piece of vinyl or electrical tape.
Problem solved. :)
Reactions: TNXR
These sensors will allow your anti lock brakes to function correctly and will keep that annoying light off on your gauge panel after a 21", 23", 26" or 30" front wheel is installed. If you have ever ridden at night with this light on you know how annoying this can be.
Apparently it IS bright. Haha.
Not sure if they ship international but shoot them an email they can probably work something out if you can't find local solution. Tell them what you have now they can probably tell you if this would help you before you buy it.
I´d like to see pictures of your bike, it made me curious!
Discussion Starter · #7 ·
it now has the front mudguard and shotgun pipes
253482
253481
So much better looking than original!
Discussion Starter · #9 ·
I have ordered an ABS ring for the 23" front from USA, hopefully that solves the issue as its not cheap with our import tax and exchange rate
I hope that fixes it for you. :)
1 - 10 of 10 Posts
