1 - 2 of 2 Posts
Hello everyone, Has anyone ever removed just there mufflers from there Vegas and if so is it hard to do? Is it just the bolts that I see connected to the bracket that holds them on? I'm sending them off to get modified.
How many pieces is it? My XCT was in sections. I removed the muffler section and it was not that hard. Remove hardware and then took a 2x4 and had to carefully smack it out due to expansion from heat. Make sure you get it all the way back in when you reinstall it though. Don't want any leaks. Could cause your bike to run screwy
Sent from my SAMSUNG-SM-G870A using Tapatalk
1 - 2 of 2 Posts
