1 - 3 of 3 Posts
Hi Justin! Welcome to the Victory forum! I am not an expert on these things, but I believe anytime you modify your fuel/air ratio, you need to have one. You will have to reprogram it because your bike will not run right otherwise. I'm sure someone will correct me if I'm wrong.
you should be fine just adding exhaust. But if you do Lloydz air filter then you want a PCV and you'll need one for a 2016 and dyno tune
1 - 3 of 3 Posts
