1 - 20 of 22 Posts
2016 Empulse TT from Victory Motorcycles
This is a street legal electric race motorcycle. Built on the same platform that set an American lap-speed record at the Isle of Man, it accelerates up to 100MPH+ and the battery fully charges in 3.5 hours. Where it matters most, the Empulse TT is fast. It is 10,400 watt hours of proof that Victory doesn?t just prove performance, we advance technology. The sport-tuned inverted front forks and adjustable suspension are engineered to provide track-level performance. It has the fastest battery charging speed, greatest lean-angle, and advanced regenerative braking system. Wherever the Empulse goes, it electrifies all audiences.
2015 ISLE OF MAN TT
Where there is no room for error, we proved performance. The Isle of Man TT is the fastest, twistiest, and gutsiest race on two wheels, the perfect location to introduce the world to our electric motorcycle. For 37 miles, we pushed a top speed of 144.34 MPH. We averaged 111.62 MPH. We set the record for an American electric bike, and it was our first attempt. We didn?t just prove that we belong; we stepped up on the podium, and proudly waved the flag of modern American muscle.
THE FASTEST CHARGING BATTERY ON THE MARKET
The Empulse?s battery fully recharges in 3.5 hours, and up to 80% in two hours. With a battery capacity of 10,400 watt hours, the Empulse TT can achieve up to 140 miles of range per charge. Advanced regenerative braking returns power to the battery every time you let off the throttle, and all this battery technology comes with a 5-year warranty. No matter how you measure it, this is the best performing electric motorcycle battery on the road.
100+ MPH TOP SPEED.SHORTEST STOPPING DISTANCE. GREATEST LEAN ANGLE. RIDER-SELECTABLE SPORT MODE.
You can take the motorcycle off the racetrack, but you can?t take the race out of this motorcycle. The innovative drive train is designed specifically to maximize power delivery and speed, while the dual Radial Mount Brembo brakes bring all that power to a quick stop. The high performance adjustable rear suspension and sport tuned inverted front forks let the rider attack every corner, so no matter where the road turns, you can drag a knee. ??
Specifications
2016 Victory Empulse TT
MSRP: Starting at $19,999 USD
Engine
Type Internal Permanent Magnet AC Induction
Peak Motor Power 54 hp
PEAK TORQUE 61 ft-lbs
TRANSMISSION 6-speed gearbox with multi-plate, hydraulic activated wet clutch
BATTERY Brammo Power Lithium Ion
CHARGE TIME 2.0 hrs (Level I / 20 to 80% SOC) 3.5 hrs (Level II / 0 to 100% SOC) 8.0 hrs (Level I / 0 to 100% SOC)
EMISSIONS None
MAX SPEED 100+ mph / 161 km/h
DRY WEIGHT 460 lbs / 213 kg
Good catch Russell, and I hope it is for real. Guess we'll find out tomorrow (the 28th that is)
But what is the range on the Vic electric Empulse TT?
G'day,
Vinish
I had an Electric bike,
The problem with it was every time i made a ''U'' turn the extension cord would get tangled in the rear sprocket...:crzy:
130-140 miles before needing a 3.5hr charge.
That would work as a commuter bike for me easily and, I suspect, most people. However, if all you want is a bike for commuting to work, get a used Honda Rebel 250 cc for $2000 and get 70mpg or get a little Ninja (Ninjette?) used. The cost difference between these and the $20K for a new Vic electric bike would buy a lifetime of gas for either of these small bikes.
G'day,
Vinish
G'day,
Vinish
I agree... The amount of energy used to charge that battery once probably equals 6 months of pollution on a little shadow or ninjette. Green is cool though so Vic will probably sell the **** out of these things to the hipsters.
Dry weight ?? Meaning without the driver ?
Guys will never buy it cause there will be no oil debate over it or what pipes should I run
Hey boss instead of a pay raise can I have extension cord and electrical plug inn
What do you mean adding the stereo took away 20 horse
I would've preferred that Victory dropped the gearing and went with the single speed transmission but good news, if true.
Most of the hybrids now have regenerative braking. In simple terms, it uses energy generated from the brakes being used to charge the battery.
Now, this may sound like a dumb question, but with the transmission being a hydraulic wet clutch deal, does the trans fluid have to be changed every so often? I would imagine so...
Edit.... I read the motorcycle.com review of the empulse tt and it does say that the fluid has to be changed every 6,000 miles
1 - 20 of 22 Posts
