1 - 6 of 6 Posts
My 2015 Vision randomly will just go dead while riding. All the electrical is gone, dead. I pull to the side, wait about 30-60 seconds and all of a sudden it will all come back on, I can start it and take off again. This has happened about 5 times. All battery cables, connections etc are good. Any ideas? Thank you.
Sounds like battery or battery connections.
Main circuit breaker near the battery could be failing.
It's a 99% chance it's one of these two issues. The breakers on these go out way too often and these bikes are very sensitive to intermittent voltage such as with a loose connection. Star washers and dielectric grease are our friend on these bikes and the batteries.
this is the breaker and its under the plastic cover behind the battery. You should have 12v going in and 12v coming out.
if you touch the two terminals with a screw driver you'll by pass it and bike should start.
could even be the clutch safety switch. lose connection
I'll check out the main breaker and double check the connections. I ordered a breaker since it was only $11. This is my third vision and first time this has happened. Thanks a bunch everyone.
1 - 6 of 6 Posts
