1 - 20 of 20 Posts
Well I will be taking my Vegas in next week for the 500 mile service, also to address some noise issues. I noticed the first day I had the bike, I had it sitting in the sun on a pretty hot day, well i walked out and saw it was dripping gas, i figured it was from topping the tank off and the gas was just expanding from being hot. well today I have about a half tank and its dripping the same amount. hopefully they can get this corrected.
How high do you fill it? I fill from the right side, bike on kick stand and take it to just below the neck.
Ah yeah, you probably don't want to ride it to them (or anywhere else) in that condition.
Can you tell where the leak is originating?
its just a small leak from the bottom over flow tube, when i start the bike it stops, it only does it when it sits in the sun on a really hot day.
An overflow tube is dripping with half a tank of gas?
Some people have had issues with vents clogging. Maybe pressure is building within the tank. Have you tried to open it when it's hot out? Does it blow the cap off like a bottle of shaken champagne?
This is lengthy post I wrote on a different forum that explains what is going on with the gas dripping, and my experience trying to solve the same problem. You don't have a gas leak problem, you are experiencing a condensation condition.
This long post explains everything:
I am a 2008 Jackpot owner and have experienced the same condition as your bike on many hot days sitting in the sun occasions. I have done extensive research on this and would like to pass along my findings and suggest perhaps, you do not have a problem. Let me explain.
I too purchased my 2008 Victory with single digit miles, and the factory gray gas cap installed. If it sat in the sun, gas level didn't matter, it dripped. I viewed your image of the gas drip spot; yep exactly the same as mine. Would never do it in my garage even if it was 95 outside and very hot in the garage. Even during winter storage I put a block under the kickstand to keep it more upright in my garage for added space. I filled the gas up into the filler neck as per the owner’s manual. It sat like that for months with a tank full enough the touch the cap, result, no leaks. My intention at purchase was to replace the gray cap with a chrome one, I thought this might fix the problem, NOPE still did it.
I have experienced the overflow/overfill condition when I filled the tank while holding the bike straight up. I then rode only 2 miles and parked at a friend’s house and it vented gas as the tank warmed up. But this condition is very different than what I believe you and I are seeing when we park it in the sun. It was a semi-steady flow of gas and it was very evident to me that I overfilled the tank and it was expanding from heat and pushing out excess liquid. As you stated it will do it with a 1/2 tank and perhaps even less. That would exclude the overfilled gas expansion theory, as 2 gallons of gas would not expand so much to push liquid out the cap and down the vent or drain tube.
Step #1
I reviewed the parts breakdown of the gas tank and drain system on the Victory web site parts pages. The hole on the left side of the cap well is a drain hole, and the hole on the lower right side of the cap well is the vent hole. The cap has an orange rubber tube that mates to that vent hole. The drain tube, and vent tube meet at a "T" fitting and become one, that one tube is the tube you see gas coming from on the left side of the bike by the oil filter. If gas is coming out of that tube that means its not obstructed. If you only have a 1/2 tank of gas, and gas is coming from that tube and we ruled out that 2 gallons of gas will not expand enough to vent liquid out of the drain tube, then it can't be pushing liquid gas out the tank and down the tube. So, if you see gas fumes exiting that tube that means your cap vent is working properly, so where is the gas coming from? That was my question also.
Step#2
With all that said, I contacted 3 Victory dealers in the Seattle area to address the same questions and concerns you have inquired about. I wanted to know what is wrong with my bike. The 1st said I don't know bring it in. The 2nd and 3rd dealers stories were almost the same. They told me the condition I am experiencing is; when the bike sits in the sun, the sun heats up the gas causing it to vent fumes. As those fumes travel down the tube they cool and turn back into liquid and drip off the tube, not out of it as a pure liquid running down the tube would. They assured me nothing is wrong with my cap and tank vent system, it was operating as it is supposed to and it is just something they (they being 2008 and newer Vic's) do. Still not satisfied with 2 out of 3, (cuz I'm an aircraft mechanic and I'm weird like that) I needed to know for sure. I thought of the hottest place I could park a Victory in the Sun..... I settled on Phoenix AZ. I again contacted 3 Phoenix area dealers, all three echoed the same story. If you only have a 1/2 tank of gas and you see fuel fumes exiting that drain tube then your vent system is working properly. They all three confirmed the hot fumes cooling and returning to a liquid theory, additionally they all three stated the 2008 and newer models "all do it". That was good enough for me, I was convinced, that is just what they do.
After reading the posts to this topic; checked old cap, checked old tank, no problem with either, drip still there. Replaced cap, drip still there. Replaced tank, drip still there. So lets see, old tank and cap did it, new tank and cap do it, dealer can't figure out what is wrong. Seems to me the chances you got two bad caps and two bad tanks, and mine does the same with a new cap, and 5 out of 6 dealers stated they do this drip thing in the sun. The chances all those repairs didn't fix it, and all those dealers are wrong, in my opinion would be very coincidental and highly unlikely. As I first stated, might be because you do not have a problem with your KP. However, if your dealer is able to fix this please let me know what they did.
Hope this helps.
This is NOT condensation as in humidity vapor turning to water on a cool surface, this is flammable gasoline coming out of a vent line. The fact that it got there as part of an evaporation event isn't very reassuring. I think I'd pop the cap on the tank if I had to park in the sun. The liability of incinerating nearby smokers at the next rally seems like it might be excessive. :confused:
Well I did pop the cap and it didn't make any noises, actually when it was really full you could here it venting i mean it wasnt super loud. you can see the vapors coming from the line when its in between drips. ill post a picture below .
I don't know how long it was sitting when you took the pic, but if that's the extent of it over a couple of hours, I can see why the dealers aren't getting too worked up over it. I was imagining a more substantial flow.
yeah this was after sitting for about 3 hours in the sun.
That is exactly what my bike has done since day 1. If it sits in direct sunlight on hotter days for more than a few hours it will drip. I found a new parking spot at work that limits the direct sunlight to early morning, and only a few hours in the afternoon, then it is in the shade for the remainder of the day. No Drip!! Even when it gets mid 80's and higher, No Drip. It's not ambient heat that causes it, it's the direct sun warming the tank for several hours creating the spike in the vapors causing the drip.
I have heard of someone straightening the tube, the elimination of the bends in the tube did not allow the vapor to collect and condensate, and the drip was eliminated. Even with that, the vapor will still be there, it's a vent tube, that's what it does.
I guess if there are those that feel those vapors and few gas drops create a condition for an explosion, I'm not sure plugging the tube to stop the vapor is an option.
Have either one of you or possibly both of you done the Drain tube mod (eliminating the "T") that is popular on these forums?
I have had this problem also with my 2010 Victory Jackpot. I had not tried to take it in yet to see what the dealer would say. I have been concerned with this issue, so are we saying that this is what it does and trying to not park in direct sunlight would eliminate this?
XR does it
Live in the oven they call Arizona. Bike does it every day I ride it to work. It sits out in the open parking lot. Leaves it's mark everyday when it is hot out. Been thinking of putting a catch can on it to catch it. Then venting the catch can. It would still vent but you might actually be able to catch some reusable clean gas. Now if it does not actually catch enough to reuse maybe it would keep it from leaving its mark everywhere you park,ha,ha. I was thinking of a catch can like some did on draft tubes years ago(engine breathers).
If you had the California model it would not do this. evo.jpg it would over flow into the canister.
Have not heard of this Drain Tube mod can you expand what it is?
It is the modification that many are recommending to get rid of the fuel smell some of these bikes have exhibited while sitting in the garage after having been run or (in some cases) WHILE the bike is stil operating. Some had a perception that there might be some fire risk but no one has EVER experienced any fire or anything else other than a slight fuel smell here or there so many of us have discounted those concerns and never even bothered to perform it. The bottom line is that there are TWO overflow tubes that meet at a location under the seat where they "TEE" into a single drainage tube. Some type of vacuum action was found to occur do to that design so many have removed the "T" and run a second, separate tube down from that point for the second drainage tube and it solved their fuel smell issues by getting rid of the vacuum issue that was retaining the fuel that created the smell. Seems like a no-brainer that it would also address your concerns, right? Please do a search on this or most any of the 4 other Victory forums. You can use terms like "Fuel smell".
Discussion Starter #20
Sooo I'm back at the dealer..they took the T out and added a separate line...well the line they added is now leaking oil. They are acting like they have no idea where its coming from. Since the line they added is a water drain tube from around the gas cap..its only leaking oil when the bike sits in the sun. Same as the gas...its also still leaking gas
1 - 20 of 20 Posts
