1 - 3 of 3 Posts
Im having issue with blowing the ign / flasher 10 amp fuse and want to know if anyone else has had this problem and what the fix is. the fuse doesnt blow right away it takes time. and the two times it did was after using the turn signals. are the auto turn signal canceling units known to go out on these bikes and if so where do I get one ?
look for pinched wires under seat.
Look for bare wires under rear fender.
Look inside the headlight. Look behind side covers
yeah done all that I was curious as to whether anyone has experienced the same issue and what the fix was. from what I've been able to learn from the shop manual schematic Im leaning towards the auto canceling flasher unit . The fuse doesnt burn right away it takes time. and each time it happened right after making a turn using the signals. Guess I'll run W/O using signals and see what that tells me
1 - 3 of 3 Posts
