1 - 5 of 5 Posts
Hoping to get her running again. Been down for 5 years. Glad to be on the forums. Thanks.
Welcome, pics and keep us posted
OK, just picked up a 2003 vegas freedom motor transplant (13k miles on it). Also picked up the carb boot and rear sprocket off same bike. :D Now just need regulator, oil fitting and speed multiplier.
Anyone know what size AN fitting I need for the oil line connection?
Also, can I run a while without the speed multiplier without damage?
Thank you.
Congrats on finding a motor. The Vic Shop has a YouTube video on swapping a freedom motor into an older Vic. http://youtu.be/Oo7sVbyUanA this should be it. If it's not, look up "the Vic shop - freedom motor swap" Any questions about the video or anything you can probably just call rylan at the Vic shop
Thank you. I did check out the video before I purchased the engine, but it did not give the size of the fitting. I will try and call Rylan, but didn't want to interrupt him at work if someone here new the size.
1 - 5 of 5 Posts
