The TS/HORN 10 amp fuse supplies main power to pin A of the main cruise connector under the seat.
You also need the switched power on pin F which comes from the CHASSIS 20 amp fuse located beside the 10 amp fuse in the fuse box.
The ABS has 2 fuses which you can access by reaching up under the rear fender at the very back.
One is for the ABS module circuit board and the other is for the pump.
