1 - 11 of 11 Posts
Anyone know how to adjust the rear shock on a Kingpin? Any special tools required? Will be riding two up with gear and want to max out rear shock.
Pull the right side cover, remove bolts from fuse block and move it out of the way. Will need a spanner wrench to adjust the coil over.
sent from my Samsung Galaxy S III
I bought a universal spanner wrench from my dealer for about $6, it seems to work OK. Its a universal polaris wrench, not victory specific.
Do you know the part number or what model the the shock tool is for? Went to my Polaris/Victory dealer and we could not find it.
looks like part number 2877408 its a polaris number I believe, and it was $5.49.
I was sold a spanner wrench with the P/N of PV-46993. Supposedly this is a Polaris mechanic's tool only, but the local mechanic ordered extra to sell. Pricey at $35, but definitely fits the ring nut on the Kingpin rear shock. Just finished adjusting. Needed a 10mm socket with an extension to remove three bolts for fuse bracket and one bolt for brake fluid chamber. Chalk this up as the first thing I've done on my Victory. I was given the advice that a little WD-40 on the threads helps and breaking the two ring nuts loose with a little tap of the hammer helps.
A spanner wrench is best but a hammer and a punch or drift will work in a pinch.
I dont feel so bad now when I couldnt find my spanner.....:D Thanks BBob!
Hammer and punch works, but be careful not to ding up the nut to much, the two will not work smoothly against each other and will be harder to adjust in the future.
Just finished 1600 mile roadtrip. Shock was adjusted great for two up, loaded touring. Sure is a bumpy ride solo. See the advantage to air shocks. Will have to adjust back for single riding. :)
1 - 11 of 11 Posts
