1 - 9 of 9 Posts
I may have asked this question before but i need some suggestions. I am trying to adapt a wide band afr guage to the bike..... it seems to be the best way to tune. Currently its got a pc3 on it. So that being said.... since my bike doesnt have an 02 senser i need to find an afr set up that allowes me to tie the actual sensor into the pc3 so i can data log through it. Or something that will stand alone data log. Something that will allow me to bounce info back and forth for a propper tune. I know this is a bit more specific.... but any suggestions would be helpfull. As of now im lookin at an lc1 but id need to buy a stand alone data logger to actually relay data.....
Yea the lc1 is very similar. But i need to find out if that will data log through the pc......... thank you for the suggestion. I didnt really even consider the lm1. Ill look further into it.
decisions decisions
Well as of now it looks like im between the lm1/lm2 and the lc1! I still need to call and talk to somone that knows the pc3 inside and out. Maybe one or the other will tie into the pc letting me datta log from it. But at the same time i would like a gauge on my bars allowing me to keep a steady eye on it. Havent decided yet.
yea
Yea i have experiance w the lc1. I know its good stuf. But never have got to use the lm1. Seems the real differance is that the lm1 is hand held. But i want something that i can put on my bars to keep an eye on. So ill have to look in to that.
The Diamond
Don't quote me but I'm pretty sure Kevin said the other ones out there are not going to give you the accurate readings you need.
Try sending him a PM.
yea
Oh consider yourself quoted my good sir!! Lol... jm.
Yea ive heard nothin but good things about most of the stuff from innovate. I wouldnt trust anything but them and fast! And personnally ive had nothing but good experiences working with innovate. The only two questions are.... like i said, one, data log through the pc giving myself a map to referance, and two, will it allow me to wire a digital gauge to it allowing meto keep an eye on afr. The one that allows me to do both will be the one i buy. I know the lc1 will allow you to wire it into other monitors like a mega squirt. But im not surethe pc3 will read its output signal. So thats the big question in the end. If the pc3 will read the lc1 ill buy it. And since i have experience with it that will make tunning and install a breaze. Ill have to call kevin in the am and see if he has any first hand knowledge of this combo.
While the inovate will not log through the PC3 it will log, and chart it into cells that can be translated for use with the PC. I have to admit the logging software from inovate is a PITA, but it will get the job done. Make sure you get the inductive pick up for charting RPM
1 - 9 of 9 Posts
