1 - 4 of 4 Posts
Hey all,
I added Bassani exhaust and a PC5, now my bike is running rich. So, I'm looking at getting an air filter that flows more than stock to bring the bike back to a bit leaner. Any suggestion? The program on the PC5 only had exhaust + high flow filter, currently running stock air filter.
Go right to Lloydz he has what you want and every body sells what he sells but he can tell you what works best. The others guess
I just received the Vic performance filter which visually appears to be the same animal as a K&N. May be wrong. Done little research on it but I'm going to rock it in the High-Ball unless I get silly and go with cutting out the stock box. If I do, I'll consult with Lloyds.. may require torque tubes and cams to really take it to some next level.
1 - 4 of 4 Posts
