1 - 7 of 7 Posts
Hello. Can anyone recommend an air/fuel meter that records the ratio and allows for afterwards review? I have the VFC III and would like to tune it after seeing a/f ratio under idle, acceleration, cruising, etc. I see I could rent the real-time, analog SAFR gauge for $20 without recording capability.
Thoughts?
Thoughts?
You can probably sell your VFC3 and get this Doebeck Gen 4+. Comes with the fuel controler, sensor and gauge.
AFR+ - Air/Fuel Ratio gauge plus EFI controller. #1 Fuel trimming and closed loop controller.
That's what I would do if I wanted to monitor and change the AFR I were running.
I still am undecided if I will get this Doebeck or go with a VFC3. If I decide on the Doebeck I will need to weld in an o2 sensor bung since my 2007 pipes dont have one.
I had an air/fuel set up on my cross country to tune the vfc it worked out every well.
I sold it quite some time ago after I tuned me VFCIII.
1 - 7 of 7 Posts
