1 - 5 of 5 Posts
Why would this be a bad idea and not work?
Using a single long thrush. Cut it in half and cap the cut end. On the input side weld a flat piece of metal. Gut my CCT muffler, pulling out the baffle section but leaving the inner liner in. Press the cut thrush into the shell down to where the metal seals against the front inside of the CCT housing. End goal is to have a few inches of the end muffler body left.
I guess sound wise I am looking for a deep tone but without the harshness. I'm thinking the last section would help get the deep tone and the thrush would quiet the exhaust down and provide some back pressure.
Why would you do either, if your going to the trouble, just DO the whole thrush, welded at both ends, true 2 1/2" slash cut tail pipes that fit just inside the lip of the stock tail cones.
Actually if you want it welded both ends it's more like the lower one internally :D
1 - 5 of 5 Posts
