1 - 15 of 15 Posts
I wanted to add a Powerlet outlet to my right side bag , I have a lot of experience and trust in the Powerlet products and recently added an outlet to my side cover too , to power some heated gear . I wanted power in my bag for charging electrical components while at the same time keeping them out of the elements . The factory hole in the bag is much too big and the Powerlet outlet just dropped through the hole , this is where my BFF Ric came in . After getting his best selling laydown plate bracket , I asked if he could use the same material to make me a plate that I could secure to the inside of the bag that I could bore a smaller hole in to fit my new outlet plug . This is what I got , hole already drilled in the perfect spot , Thank you Ric ! This little plate is a PERFECT fit and looks factory . He has these available for anybody interested , there is factory wiring under the fender exactly for this procedure and reaches the bag perfectly .
Nice! thumb up
Thanks Mark ! Easy to do too .
Thanks for the tip LM.....thumb up
I used the 3M adhesion promoter for a rock solid permanent mount , man you better get it on straight the first time or you will need a crowbar to get it off . :crzy:
Mags must think that,just cuz I'm now retired, I'm just sitting and twiddling my thumbs, looking for things to do. He's partially right!:) I do have the template and can make more, if there is interest. I'll figure a price per the amount of requests. The more, the lower the price.
I'm able to keep the price of the laydown license plate bracket down to $35 because of the volume I sell and can produce them in groups. There are 29 steps to making the bracket, so doing them production style saves time.
Nice work, Mags (and Ric)!
That looks great Mags and Ric- when I get a CC I will definitely be ordering one.
Nice addition Mags thumb up...I've been waiting to see how you did this.
So, this adhesion promoter -- e.g. [ame]http://www.amazon.com/3M-Adhesion-Promoter-Sponge-Applicator/dp/B004TGJU2A[/ame] -- is used in addition to automotive two-sided sticky tape?
I ask, because I'm unfamiliar with the adhesion product. I've always just cleaned the surfaces with alcohol first. But while that worked OK, it's never been what I'd call permanent.
(BTW, I bought RicZ's laydown license plate thingy almost three years ago. Nice product.)
I suggest ABS cement--the stuff you use on plastic plumbing.
Nice!! You mentioned that you can access the power for the plug via wires under the rear fender. Do you happen to remember which one?
So, this adhesion promoter -- e.g. http://www.amazon.com/3M-Adhesion-Promoter-Sponge-Applicator/dp/B004TGJU2A -- is used in addition to automotive two-sided sticky tape?
Yes , apply the adhesion promoter per the sponge applicator to both pieces and let dry 2-4 minutes or so , apply tape and assemble . Permanent , is an understatement .
Yes , if you look up under the fender they are secured by a push pin / zip tie . They have a small and a large spade terminal two wire wrapped in loom . I cut the terminals off and re-crimped the ones supplied with my socket kit , checking for the correct polarity of course . thumb up
Discussion Starter #15
I was going to use this product in the beginning , but had the 3M tape and promoter on the shelf , and there was plenty of contact surface for the tape to bond to . Came out great Ric , thanks again for your engineering skills , top notch !thumb upcheers
1 - 15 of 15 Posts
