1 - 8 of 8 Posts
Lookin to see whom has done a double din stereo, touchscreen, NAVI that can share the detailz of how they got it all mounted to the front of their XC or Magnum wing.
Seen several vids on Youtube of custom fiberglass job, but got a $3500 quote for that. I cant do the fiberglass myself. I saw one just float mounted I liked like this, cradle, etc
Dont care if hand controlz are forgone
There are those guys online that mod faceplate stereos to fit on the front like that where the display and buttons go.
They might be able to do as you are showing there with a double din model.
Your still looking at some cost if it is possible but should be less than a full fiberglass job.
That looks very close to tank.
Can you still rotate bars full range?
Discussion Starter · #7 ·
I shot u a message Chad
By chance do you also know where to splice into the harness to get the pre-out signal for the rears as an input for an aftermarket amplifier add on?
It sold already. I am almost done going back to stock now.
I don't follow your question, on the signal for the rears.
Are you just looking for the wires that go to the rear speakers? If your are adding an aftermarket radio and amp then take the stock amp out.
1 - 8 of 8 Posts
