1 - 6 of 6 Posts
Have a problem and seeing if anyone else has had issues. Have a 2013 XC. Bike started having a problem where it will randomly start idling and bouncing back and forth upwards of 400RPMs difference. Driving with constant throttle, the same thing happens but with less of an effect: continual jerking as it goes up and down a few hundred RPMs. Yesterday the first corner I pulled up to it stalled when I put in the throttle.
Throttle position sensor? Asked the dealer, said could be a vacuum leak somewhere too. I'm afraid that it might not be covered under warranty either way, and I'm having them check into it before I bring it in.
Check your battery terminal connections and make sure they are tight. I will bet you a six pack that's your issue.
^ Agreed, or the battery itself could have gone bad.
This and that....
Had a battery that was starting to go south and this would happen sporadically
Try resetting your IAC.
a) Kill Switch set to run
b) Turn Key On
c) Let fuel pump prime
d) Turn Key Off
e) Wait for IAC to cycle. It's an audible sound and you can also feel it on the right cheese wedge
Repeat steps 3 times then start the bike.
1 - 6 of 6 Posts
