1 - 3 of 3 Posts
I need to know the exact weight of my bike when tank is full, any help here??
Sorry, I might not be able to help you there, but for what it's worth, the listed dry weight is 635 (lbs). You would have to estimate the weight of oil, fuel, and brake fluid to get the number you're after.
- The dry weight might be listed with a 5 (lbs) error factor, so you have to add 5 (lbs) to the equation.
- 5.0 (qts of oil) x 7.5 (lbs/gallon) x 0.25 (gallons/qts) = 9.4 (lbs)
- 4.5 (gallons of fuel) x 6.073 (lbs/gallon) = 27.3 (lbs)
- Brake Fluid estimate has to be under = 8 (lbs)
Add all these up, and you get 684.7 (lbs). This is not the "exact weight" you were asking for, if there is such thing as an exact weight, but hope this helps you out.
I'm prtty sure it's listed in the owners manual.
1 - 3 of 3 Posts
