1 - 17 of 17 Posts
Hey there all,
So, in the 11 months and 16k miles of my '15 XC ownership, I have come to the conclusion that I have to do something to save my lower back.
It feels like I'm leaning too far forward when driving. I currently have a Grasshopper backrest, which although is better than nothing, it doesn't come close to fixing the problem. I have even added a lumbar roll to the back to push me forward, and put some pressure on my lower back.
I'm thinking that some Ape hangers and maybe a Utopia back may do the trick.
A couple of questions I have about it:
  • Has anyone here had this issue, and if they have found the solution (for them), what was it?
  • If it is apes... which handlebars work best? I'm thinking that giving me about 4 inches of lift over stock, and a couple of inches back would work
  • What apes are the easiest to change out? I'm OK with a wrench... but the thought of tearing and replacing the cables/wires is daunting... I would prefer not to do that
  • Do the Utopia backrests give enough support/adjust-ability that I could go with shorter apes, and just get some that are 4 inches or so over stock?
Sorry for sounding like a nincompoop. I have never done handlebars before, and need some advice.
Thank you all for your input
You didnt mention height, etc & that really matters when selecting bars. Im 6' with 32" inseam. I went with FMB mid-apes (called 10" vs 14 or 16" apes). Wanted a better angle, but still behind the fairing. They are just a touch forward (arms straight when using backrest) but I may be able to pull them back a little more - hasn't been enough of an issue to mess with before winter. Most of the aftermarket pullback bars will give you 4" of lift WITH pullback - you have some adjustability there. Most of the pullbacks don't need longer cables/hoses. Getting my knuckles out of my lap helped me, but I'll point you more directions! Grasshopper backrest is fairly hard foam (have one on Vegas). I use the vic backrest on my XC and it's much more comfortable and adjustable. You can pick them up used for cheap, or get some padding on your grasshopper one. Be sure NOT to set up your backrest to push your butt forward off the seat curve, or you'll be putting pressure on your back directly as well as pushing yourself off the sweet spot of the seat, which ends up putting more pressure on back also. You didnt mention the seat itself, but that is probably a factor also? Maybe the east coast guys can point out a seat shop in your area that can shape/pad it for you? They can also move you forward, up, down to get you adjusted if that helps how you sit on the bike. I'd volunteer to help, but you're a long way from Boise! Good luck!
2010 Cross Country / stock 106 with glasspack mufflers
Adding a backrest did wonders for my back, but I'm with you - the full relief will eventually include some 2" pullback bars so I can sit all the way back in the seat without having to lean forward (unless I choose to). I used to think I wanted taller bars too, and I still might, but an even bigger problem for my physique is the angle of the grips....they're turned in too much for me, forcing my elbows to twist inward, instead of a more relaxed outward flex. I think if I could correct the grip angle, the height would not matter as much. That grip angle is one thing I don't know how to determine when comparing different bar specs. Honestly, I am about to pull off the controls and try modifying the angle myself by sticking a pipe inside the hollow bar-end and grunting till it moves an inch.
I just replaced my XCT handlebars a couple of weeks ago. I bought the Klock Werks Klip Hanger bars. They have adjustable clamps which allow me to fine tune the grip angle, pull back, and lever angle. Not quite finished tweaking them, but I love them. Cost was about $400 shipped and I am still using my original cables/wires.
Klock Werks Klip Hanger Handlebars for Victory - Iron Aces Speed Shop
You don't mention what bars you currently have so I assume they are stock. If you are looking to lean back a little bit, try the Victory 2" pullback bars. They can be installed quickly and don't need any lengthening of wires/cables. They made a HUGE difference for me. I'm 5'-9.5" tall with a 32" inseam. With the stock bars, I was leaning slightly forward which caused my head to have to tilt slightly upward which gave me neck and shoulder strain. The 2" pullback bars solved this. You have some amount of up/down movement capability with the stock and the 2" pullback bars as well.
G'day,
Vinish
The wrist angle was why I i usually changed mine. By the time I lifted the stock ones out of my lap, the heel of my hand was higher than my thumb. The new ones are better, but I would still like a more angled grip position. Building a set for my Vegas so I get what I want instead of my firearms being angry of the $300 ones. I looked at Bright's klips also, but just can't get past the price. For $400, I just need to sacrifice a day & build some or cut/re-angle mine & TIG them up, & powder coat them again.
For the Vegas, I'm going to start with my factory XC bars & angle-cut the bend. Goal is to get mid-height with a good angle. Should be doable on any cold winters day!
Broggy, why did you pick the klips over the ness modular? Probably a difference but I've never seen either in person!
Well, honestly I hadn't really known about the Ness modulars, but @PaiN actually bought the same ones and I liked how they felt.
@broggyr I really like how those bars look man. Are the clamps splined to adjust incrementally, or do you have to eyeball it?
I have the Victory riders backrest and Victory apes on my CCT. It's a very comfortable riding position with excellent back support and no shoulder pain at all. Fill the tank, ride till empty, fill it up again, repeat.
How did the cables/wires look after you were done with them? Do you have pictures? Those are pretty much the same as the Ness modulars I was considering.
The clamps are not splined; they are smooth bore for infinite adjustability. You must eyeball it or use a protractor, but I'm not that picky.
Ugh. That would wreak hell on my obsession with symmetry.
Points awarded for appropriate use of a semicolon, though lol
Reactions: broggyr
not everyday we see a semicolon these days ;
or perfect symmetry ...if it looks right by eye its ok!
(interesting fact the ancient Greek ruins, Acropolis, Parthenon etc. were constructed untrue symmetrically so as to look correct to the eye!..that's a fact Jack!)
Reactions: Luciferiad
@OP , I had emergency spinal surgery in 2013, and bought the cross roads in March of 2016. I added the hardball mini apes for the height and the Kuryakyn Multi backrest. It has a truly MASSIVE back pad and is wickedly comfortable, while also offering the lumbar support I needed to get back on a bike. And for those rides where you have a passenger, it flips up and becomes their sissy bar.
Hey @victoryismine you live in Maine according to your profile you should have a few winter months to figure handlebar installs out. LoL!!!
On a more helpful note........use Witchdoctors videos, Victory Forums own @wspollack website and post......................................
Victory XCT HeliBars Installation
http://www.victoryforums.com/34-victory-cross-country-cross-roads/98705-helibars-webbikeworld-article-my-xct-installation-addl-gallery-video.html
Also the Utopia backrest is awesome! FMB has some pullback bars VICTORY CROSS COUNTRY VERTICALLY CHALLENGED PLUS 3 MONKEY BARS, Harley Custom Handlebars- Custom ape hangers
Also Vicbaggers has pullback bar as well. The choices stated in previous posts are fantastic. Helibars are in that category as well. I have Kewlmetals Meathooks and I am happy. It comes down to your taste! Don't be scared to tackle it plenty of help in the witchdoctor videos and the wspollack website. IMHO
Discussion Starter #17
LOL yup... winter is right around the corner! I still take the bike out on occasion, though. I'll do that until the snow flies. That's when she'll get put up for the winter. I bought a 2016 Sportsman this year to help me get through the winter this year, though!
Thank you for the links! It looks like I'm going to be rather busy this winter :wink
1 - 17 of 17 Posts
