Sorry for the late response. Yes it is still for sale. Have you tried running the diagnostic test on your bike to see what codes it is providing? Try checking that first, I'd hate for you to make the same mistake I did and purchase an expensive part for your bike that you don't need. Check your manual for the self-diagnostic on the auto cancel module. I posted the steps below to help out also.
1. Turn ignition key OFF.
2. Turn hazard switch ON.
3. Turn ignition key ON.
4. Pull and release the front brake lever (or rear brake pedal) 3 times within a 3 second period to enable the diagnostic mode.
- All 4 turn signal bulbs will illuminate for 1 second then go out, to indicate the diagnostic mode has been enabled. (Only bulbs in working order will illuminate)
- The "blink codes" now start flashing on the turn signals.
Then refer to this chart for what the codes mean...
