1 - 20 of 34 Posts
Ok I keep seeing different threads about the auto tune setup.
I see people running all different ratios at different spots.
Admittedly it's understandable, different bikes, different configurations etc.
So I'm curious.
2012 CCT.
VM Cams, PC-V w/A-tune, Lloyd filter, unlocked ECU, timing wheel set to +2, nascar6 re baffled pipes.
I hear all these reports about bikes pulling like a freight train etc.
Well when I first got my cams and it tuned with the VFC, didn't feel like much.
Upgraded to the PC-V with A-tune, it's better but I don't feel like the bike is running all that strong. My A/F ratios have ran anywhere from 13.9(cruise) to 13.4 full throttle range to 13.7 cruise to 13.0 full throttle.
Just not noticing much difference. So i'm curious for those with similar setups to mine,
What ratio/RPM range are you running? Are you happy with your performance/mpg...?
Aren't you supposed to have it dyno tuned first then the auto tune maintains it.
Go get it dyno tuned by a reputable tuner , you won't believe the difference . Then you won't need the AT .
well therein lies the problem. No reputable tuner in my general area.
I'd rather not toss $200-300 towards someone unless I know they're doing their job properly.
That's why I went auto tune and I'm asking what people are running for AFR's
If I had the time I'd run to the Vic shop, it's only 6 hours away but it's late season, it would be an overnight trip and I just don't have the free time right now.
I was lucky to be in Des Moines on business a few years back, Rylan put my cams in and dialed in the VFC3 but that was his pre dyno days.
Was never really happy with the cold surging so I went to PC-V. It runs better with it but just curious what has traditionally performed the best AF range/rpm etc for my configuration?
There are a few guys here the swear by the autotune , hopefully they will chime in and help make setting it up easier for you .
Maybe sent Rylan a email and tell him your setting and how he could improve on them.
Well I've attached my PVM file as an attachment zipped up in case anyone is curious enough to take a look at it.
Until I can get back to Iowa and have it tuned by someone.
It could very well be that my bike is fine, just that my idea of performance greatly differs from someone elses idea of performance.
The fun thing is the ability to 'play' with the settings to find the happy spot, the downside is the butt dyno is different from person to person.
Gossamer , read this , it is all you need to know . This covers just about everything on the AT .
http://www.victoryforums.com/showthread.php?t=24969&highlight=STINKYBUTT
I know what the AUTO TUNE, and how it works. What I'm asking is what are people WITH my setup running for A/F ratios?
I've had it on the bike for 15,000 miles or so now(currently at almost 38,000). I've had cams in my bike since the Vic shop installed them in 2012.
I've played with various settings, fuel maps etc. Trying to find the sweet spot performance wise.
Asking if anyone wants to share their settings so that I can try them a while.
The beauty of this device is the end users ability to play with it, change it, look for better options.
I know i'm not the only Cross bike with cams/filter/etc running this tuner.
nothing to say sorry for, maybe my original request wasn't clear enough.
just one of those, I know what my findings have been, curious as what everyone else comes up with for their setup.
I know a lot of people spend a lot of money with various people for their tunes.
I know a lot people don't have good tuners in the area so the A/T feature is a nice thing to have and allows endless playing.
Season is near end for me so I'm looking at playing around before I put her to bed for the season.
ImageUploadedByMO Free1411579740.950005.jpg heres mine , no cams though
Not knowing how the auto-tune works myself, I imagine if you can dial in your own AFR's in different areas of the map, you can probably tweak it to be pretty darn seriously optimized.
Kyle set my initial throttle pretty much at that "ideal" AFR, then the mid-cruising range at a fairly MPG-friendly AFR on the leaner side but not too far lean, then it gets pretty rich at WOT. Wish I could remember the details better what those AFR #'s were.
That said, a set of Freedom duals just showed up at the door, so all bets are off now on that dyno'd map. Will try a canned map for my setup and see, then maybe play with the AT down the road. You bet I'll be comparing the dyno'd tri-oval map to the canned Freedom dual map, just to analyze the differences.
yes you set your af mix where you want it and it trims the map from there, just need the right af mix.
I imagine then it could be a fun iterative process then in a certain throttle position and RPM range simply addressing the weak spots with a tweak at one or both cylinders. I bet after the 1000th adjustment a guy could get pretty good at it. :)
Why are you so stubborn? Write Rylan and ask for a map. It would be so simple to do .
you have a pcv now ? with or without auto tune?
its pretty easy to do, nice thing is when you have it and you load a canned map, you can see why it ran so bad!
1 - 20 of 34 Posts
