1 - 10 of 10 Posts
That looks great. Perfect spot to install them. thumb up
Did you make them special or is it a kit? Looks great!
I purchased them from a place in Ca. GR Customs. There made by Knight Riderz mine were 7" long 21 led's (they also have 4" long )and come with strong double sided tape. I made simple brackets bent in a vice. Bolted to rear bag frame.I have some other pics I can send you.
I removed seat and disconnected plug that connects to tail light, Used a meter to find which color was running and brake then used 3m splice adapter. Pretty easy. It took longer to decide where to mount them than it did to wire.
I mounted a set of LED pods on the bracket just above where you are pointing to in the picture. They fit perfect and are wired up for brake and turn.
You are correct in stating that the additional lights makes a big difference. Plus it is a great spot to mount them.
1 - 10 of 10 Posts
