1 - 5 of 5 Posts
Has anyone fitted a Banshee horn?
Pictures of install, connections etc would be great...
I have one on order.
regards,
Derek:)
Looks the same as the Stebil and the Whol BadBoy (Pardon my spelling). I installed one on my VN900 and it is very loud. Installation was fairly straight forward, but be sure to use a relay to drive the horn.
... be sure to use a relay to drive the horn.
:I agree: Some have skipped that step, and while the horn might work at first, it will eventually blow a fuse. Install with the relay or do not install at all.
I searched and can not find it,,,, I put my relay up front in the battery cover area, mounted the horn under the rear fender, there was alot of room and only had to run 1 wire back. I got it off this site where someone explained it well.
Cheers, which site?????
1 - 5 of 5 Posts
