1 - 3 of 3 Posts
Clutch starting to slip a bit and was going to replace with Barnett clutch pack. They only question I have is on the friction plates (fiber plates). I have looked them over, rubbed fingers over them and can not tell the difference between the rolled edge and sharp edge. I am assuming it will be on the outside tangs?? or will it be on the inside part of the frictions? I can fell it on the steels just don't see/feel a difference on the frictions. Any help or insight from those of you that have installed these would be great. Thank all of you folks in advance for the help.
Does not matter direction
A friend with a Vision replaced his a few months back. He actually called Barnett. Their clutch packs are the same on each side they told him. He was questing it also. Soak the new friction disc in oil before assembly. Adjust the free play correctly!
1 - 3 of 3 Posts
