1 - 20 of 202 Posts
This is 1 block of riding at 20 mph after installing a witchdoctor open belt cover to cure my belt rub. To much of my dismay after riding I smelt burning rubber to look back and see this.
Updated pics. I reinstalled cover to show problem
Allen wrench showing where contact is made
Your belt is still rubbing inside the open cover, its not WDs fault, im guessing you lowered your bike? What bike? When you lower some of the year bikes the belt hits the bolt boss, so by replacing the cover you fixed nothing. The WD cover may have a heavier duty boss thats thicker so thats why it will rub more, did you tell him you were having rubbing issues before you bought the cover?
Sent from Motorcycle.com App
As others have asked, have you called Jon at Witchdoctors and talked to him about this prior to posting this thread? They're one of the best
vendors Victory owners have and they always do whatever they can to resolve issues. As has also been asked, is your bike lowered and did Witchdoctors know this at the time you ordered your item.
Who installed it? Did they or you check for clearance issues before riding off into the sunset? WD is a very standup
guy and takes pride in his business and his customers....If there had a been and issue WD would have made it right, if I was him now I wouldn't!
If clearance was an issue to begin with , was it checked after the new cover was installed , if not , why ?
Can you post more pictures , from different angles of the cover ? Maybe your belt was smoked before you put the new cover on and you just didn't notice it :rolleyes:
Soooo you WD blowhards come to defense of WD when obviously the stock cover didn't rub. How many of you guys have checked the clearance of the belt to cover? How many of you guys jump on here to report a problem as soon as you have an issue? Thanks for the heads up on another issue from one of our victory vendors. Just to mention when you adjust the belt you don't adjust it for clearance, you adjust it for tension....
WTF! he said in his post his belt was rubbing so he put on the WD cover to fix it, He obviously doesnt know why it was rubbing in the first place or he would have saved his money and ground down the bolt boss to solve his issue.
Seems it did rub.
D , please define Blowhard ! :ltr:
From looking at the first post and the picture i'm with LILMAGS500.
I think its the turnedout bassini pipes fault. LOL:ltr:
I'm just kidding. I had to thought. Until the poster gives us more info theres not alot to fix here. thumb up
BLOW HARD- when a woman can push a golfball through a garden hose with only her hot air. LOL
I just went and looked at WD's open belt covers , I don't see how , where his belt is worn could have possibly happened with one of these covers , WD or otherwise , I know Conquest customs offer these too. Something is awry with the installation , IMO , until further evidence is provided to the contrary . It seems the OP has disappeared for the time being .
...IMO , until further evidence is provided to the contrary . It seems the OP has disappeared for the time being .
Seems that way. Probably put his foot in his mouth and hid under a rock. :ltr:
My thoughts exactly , probably left an Allen wrench between his belt guard and belt . OOOOpS ?:ltr:
Guessing you didn't look to see if you installed it correct.
Why are you here bad mouthing Witchdoctor when you should be talking to them to get it straightened out. I'm sure Jon did his home work before putting it on the market.
1 - 20 of 202 Posts
