1 - 7 of 7 Posts
was out on a ride with 5 others and was in front,coming through mid wales,I rounded a blind sharp narrow bend at the start of a steep climb when the bike suddenly stopped. Iwas stranded in middle of road holding bike on brake the other riders and a mercedes estate car just managed to go around me,it was very close. Switched ignition on and off afew times and had to find neutral on a steep hill to start the bike again. Pulled over at a layby and found battery terminals had worked loose,tightened them up and the bike ran home ok. I was quite shaken by this and now think the "starts only in neutral" idea not so good,the time it took to get the bike out of a hazardous situation was critical,but I will check these terminals every month from now.
It is called "preventive maintenance" ...a drop or two of locktight wouldn't hurt either (blue formula)
dunno if you have this or not but on my 2007 hammer all of a sudden i couldnt start it in gear turns out there is a plug connector right at the clutch lever that wasnt connected all the way i pushed it in till i heard a click then i could start the bike in gear.Might want to have a look
Read the post Bro...He stated his battery terminal connector came loose....:crzy:
1 - 7 of 7 Posts
