1 - 2 of 2 Posts
Well once again my 06 kingpin is acting up and makes it even better when I'm stranded in lynnwood wa... I put the bike into diagnostic mode and it flashed a code 12. Anyone know what this is... I went to te dealer here and they wernt really sure so... But once the bike is hot it seems like the ignition is just breaking up and the tach bounces around and dies... If I keep moving highway speed it will keep running as long as I'm going but if I stop it dies... Fuel pressure is good battery connections are good all grounds.. I was curious if maybe it would be a crank sensor? I came to lynnwood because the bike ate another speed sensor on my trip but they dont have one... Any info would be great
Only mods on the bike is swept pipes and tune
sounds like something in the charging system, if it does not produce enough at idle it will run on the battery until it dies, shorting out. Just my thought like corrosion on regulator/rectifier, stator, wire connectors that is were I would start..
1 - 2 of 2 Posts
