1 - 2 of 2 Posts
Happy Holidays folks. I would like to install red OEM LED rear turn signals on my 2013 Boardwalk that I got from Signal Dynamics. This, so I can install a plug and play run/stop/brake module. The rear fender needs to come off for this install. I don't have a detailed service manual, and have come across nothing for guidance online. Is removing the rear fender complicated? Thanks.
I don't know how but the first step is to un-hook the ground on the battery.
Take seat off and unhook wires running to the taillight and signals.
Unbolt fender one side and stick some kind of screwdriver or punch in each hole you pull bolts out of. This way when you unbolt the other side the fender will not drop and scratch paint...
1 - 2 of 2 Posts
