1 - 5 of 5 Posts
Wanting to change out brake pedal and shifter peg from '12 XC. Vice grip is only turning the pedal. Can't see if there's a screw to undo. Need insight....
I changed both of mine with a pair of vice grips. They both screw out, you just have to get a good "bite" with them. Good luck and let me know how it turns out.
Like jwolfpac02 said - a little heat and place the vise grip next to the brake lever and turn counterclockwise - It will come loose......
Remember to clean the used loctite out of the threads and put new loctite on the new pedal threads.
Keep us posted.
clamp the vice grip down tighter and turn counter clock wise
1 - 5 of 5 Posts
