1 - 7 of 7 Posts
So my brake light works but my tail light doesn't... is this caused by a fuse or possibly something else like wiring.
2011 Vegas 8ball
2011 Vegas 8ball
Check to see if it doesn't work with both brakes. If it works with only one then the sending switch at the brake or a wire problem is the culprit.
Bottomed out before ?
Andre using TaPaTaLk
My vegas bottoms out when riding 2 up and has chewed up wires inside fender. Is there a way to stiffen up the rear when riding 2up?
look under rear fender for bad wires
1 - 7 of 7 Posts
