1 - 8 of 8 Posts
I installed 4 inch forward controls. Bled the rear brake. But now it takes more pressure to get the brake to engage. Before, I could lock up the rear with very little pressure. Now, putting my foot "through the floorboard" to get any feed back. Filled the reservoir with DOT 4 and pumped the brake A LOT. Any tips or something I missed?
Chaz , probably still some air in the line ....
make sure you hold the brake lever down and tighten the bleeder screw , before letting off the brake lever ... Its much easier and more efficient with 2 people ....
4 inchs might be to long for your leg to apply full pressure
Sorry for two replies. I don't have an issue with full pressure. Just an issue with pressure fromnthe brake pedal.
Still air in the line bud , that's all , and I got you beat ... 6' 3" and size 14 ! :D
That's a big understanding Mags.
Brake pedal or lever mushy? Gotta bleed the air out. No two ways around it guy.:mad:
1 - 8 of 8 Posts
