So I was changing my oil after work the other day, and as I was tightening the drain plug with the preset 12 ft-lb torque wrench we use for drain plugs on our customers' cars, I felt the resistance in the bolt going down, even though the wrench hadn't clicked yet. I stopped tightening the bolt thinking, "Oh, crap! I just stripped the drain!" I couldn't think of how it would've happened when I hadn't even approached 12 ft-lbs, especially since the service manual's recommended torque is 15. But I figured that at least I had the bolt on and sealed, so I'd just start saving money to fix the threads or replace the drain pan or whatever when time came for the next oil change.
Well, later on I found that oil was dripping ever so slowly out of the drain. I figured I'd try tightening the bolt to see if that would fix the leak or if it would finish the damage to the drain. As it turns out, the threads in the drain were not stripped at all; this is what happened:
After getting a new drain plug from Polaris of Portland, I managed to work the other portion of the bolt out of the drain with an allen socket bit and my fingertips, then quickly plug up the hole with my finger and put the new bolt in. It was quite a relief to know the drain wasn't stripped, albeit a rather irritating ordeal, regardless.
Anybody else ever break a drain plug with that little torque? These bikes seem to otherwise be pretty much bullet-proof. I suppose it's better to have a breakage-prone drain plug than one that'll certainly strip out the drain threads if you're a bit overzealous with your wrench, but still... that was just a bit frustrating. Especially the part where I took the bus to work. Trimet kinda blows...
Never, in all my years of changing oil in vehicles, have I ever encountered breaking a drain plug. In truth, I have never used a torque wrench on them either and I've come across many that were extremely tight.
That said, there's at least one other thread here where a couple guys have broken the bolt that holds the timing wheel on. It blows my mind that these bolts break under minimal force. Makes a guy wonder.
Sometimes torque wrenches wont click when they are suppose to, like they get stuck between teeth. Ive gotten into the habit of ratcheting it before the final snug, 12ftlbs isnt much, did it feel like you were pulling harder than that?
You can see some lateral stress results on the bolt. I'd say that someone in the past did the majority of the damage. Repeated heating and cooling furthered the weakness then your wrenching just finished it off.
As many times as that bolt will be taken out during the life of the bike I put automotive silicone on male and female and put it in finger tight and let it cure over night. Your not holding things together just stopping leaks. In ten years no problems.
Clean male and female threads with q tips before silicone.
I prefer beam torque wrenches, though not as accurate as click type you can throw them at a wall and no recalibration needed ever.cheers
I would bet we will never know how you broke that plug. 12FT-lb is next to nothing. How in the Heck can you break a steel plug in an aluminum casing anyway? My own perspective is that it was a defective part. You should be able to completely strip the casing threads and never even put stress on that plug, not that you would want to do that but the relative strength of the materials would go in that direction.
Well, it did feel like the wrench should've clicked at some point, although the going wasn't really tough to begin with. It kind of felt like I was putting a plastic bolt into the pan, the way it was going. That said, though, the torque wrench I was using was a shop wrench, and has been dropped a few times, so whether or not it actually torques to 12ft-lbs is debatable.
I used to never use torque wrenches on drain plugs in the past, but I figured I do it this time since I had one at hand and I've gotten in the habit of having one on hand. If the recommended torque for a drain plug is next-to-nothing (like 15ft-lbs), it's probably best to stick with that.
I kind of wonder if these drain plugs are actually steel, though, if they break like mine did with so little force. I'm kind of guessing the bike's previous owner probably did over-torque on several occasions, though, which would ultimately led to this, but either way, I'm definitely going to be using my (much better kept) torque wrench withe drain plug from now on.
Never use a TQ wrench to tighten something so delicate. It's in the manual because it has to be. Tighten by hand till snug then use your wrench to snug it up a little more. Just like your oil filter. It's a feel thing. Change the copper washer every other time is ok too. Never ever had a plug leak on any motor of mine.
Depending on what ftlbs the wrench is good for if 12 ftlbs is the very bottom it may have clicked but very quietly and softly. Nothing wrong with torquing an oil plug, just know how to use it and be familiar with it. I torque about 99% of the bolts i tighten.
If that torque wrench has been dropped repeated times then it can no longer be trusted.
Also if it is always left with tension on the spring it can no longer be trusted. A click type torque wrench has to be dialed back to the bottom of the scale or it will go out of calibration.
That does not look like a stock drain plug. It looks like one of Witch Doctors drain plugs because of the color of it. Is it one of his magnetic drain plugs?
A torque wrench is not accurate for the first 20% of the scale on a click type torque wrench. So if that torque wrench goes from 10 to 75 foot pounds 12 foot pounds can not be relied on as being accurate.
To many oil change places way over tighten drain plugs. I use a Snap On 5 to 75 foot pound torque wrench on my drain plug and I always release the tension on the torque wrench after using it so the it does not fall out of calibration.
You could also use a 50 to 200 inch pound torque wrench to put you well over the first 20% of the scale. 15 foot pounds would equal 180 inch pounds.
I don't know about the calibration thing of OP's wrench and I don't know what that drain plug was made of either or where it came from. I do know when I see something that is over torqued and that plug was definitely over tightened but to the point of shredding it ?
Same Crap happened to me. No torque wrenchtough.my Allen is stripped. A solid head, hex plug would've been better. Hopefully witch doctors uses better steel
Tired of the heat generated from my V-twin. Contemplating two options because I ride 90% of time two up and have recently decided to pull a small trailer behind the bike. The first is to add a SPAL 5.2 inch puller fan on my 2015 CCT. Puller fans apparently generate more air flow than the same...
I see a few guys liking this oil but I can only seem to find the t6 diesel .Ive been to a couple different wally worlds. There has to be a difference right?
I have a partial gallon left from my oil change last year. In my area Rotella only comes in gallons. Is it ok to use the leftovers from last year in the bike? Can I use whats left and add to it or should I just use it to top off after a new gallon?
Here:
https://www.peterverdone.com/archive/lowspeed.htm
If clicking on the link does not work try opening it in a new tab.
Check out the other links on the page also
Amsoil has put out a 20/40 formula designed for new Victory/Indian motors. Is there anything different about new Victory's and Indians that would require Amsoil to design a new formula. It looks as though there are now three companies making 20/40 oil exclusively for these bikes. That would...
