1 - 7 of 7 Posts
Just got back from visiting Rylan Voss in Iowa this past thursday to get cams, vfc3 & timing wheel. Great service and friendly to boot! Here's the results before & after:
Numbers look good. On the first run did you still have the o2 sensors plugged in? What setting did Rylan put your timing wheel at? One more quesion..what exhaust are you running? Thanks
No o2's at base dyno, read my sig for exhaust. I assume the timing is +4 as is most are set as I have read.
Cool, the sig line doesnt show up using the app on my pad. But looked at your profile and found what i was looking for. Cheers and enjoy
Guess I should add to my sig that I have the Lloydz rev extend flash - really helps it come alive and keep pulling!
1 - 7 of 7 Posts
