1 - 11 of 11 Posts
I have a 05 Ness Vegas with a 180 55 18 on the rear I would like to put a little wider tire on seen post about 200's poor handling and starting wondering if 190 55 18 work and has anyone tried it. Was there any issues?
It does handle well now but was asking if I might have any problems and may look better with a little wider tire just not sure if I want to be the first to try
it will be slightly taller also
where are you finding a 190?
Motorcycle Superstore, but after looking closer. I found them in 17 inch not 18 in all brands looks like it's a 180 for me. but thanks for all the info
look at dennis kirk or jp cycle you'll find more tires and maybe better prices
I'm sure you can make a 190 fit, BUT:
-It will void the tire warranty if too narrow of a rim per tire manufacturer specs.
-It will sit taller.
-Once you "over-round" the tire to fit, it will probably be narrower than a 180.
-It will handle worse.
-It will wear in the middle quickly.
for the hassle of adding a 1/4 inch stay with the 180 you'll be better off
1 - 11 of 11 Posts
